Its not used at present, but maybe used in the future. The intention is that it can be a mechanism for the Display to report unplayable files back to the CMS so that they:
Can be adjusted by an admin
Are removed from the Players rotation (so they don’t just sit there and fail)
I’d recommend creating a dataset for your own purposes - or using a completely custom table that Xibo knows nothing about.
