As well as standard Dooh, we also offer experiential campaigns. One of the most popular is spin to win. Historically this has been a wheel nailed to a board with win/lose option.
I decided to have a go with making a digital version using Xibo.
So i found this website (www.pickerwheel.com) that allows you to customise a wheel, and it also gives you an iframe to embed.
We create an image, with a space for the wheel and set this as the background. Using the embed widget, copy and paste the iframe into HTML field.
We bought the displays with a windows device pre installed. It looks like they’ve butchered a laptop and used the board to me. I have replaced the PC with DSCS9X as they’ve died. The last batch of displays we bought were pre installed with a RPI4. I’d have loved to used XIBO Linux, but instead I installed android onto the PI. It runs XIBO with no problems. I use the windows machines for spin to win because I still haven’t managed to get android to run at a 5:4 resolution.
Because its touch, you don’t see the mouse pointer on display. It just looks a bit more professional. It’s also easier to present the customer with a screen that requires just a single tap to spin the wheel. There is a bluetooth keyboard/mouse connected as a backup.
Basic games on platforms like Xibo are a fun way to stay entertained, but if you’re looking for something more engaging, the betbull sign up offer is worth checking out. It adds a layer of excitement with its welcome perks. Modern gaming is all about blending creativity with rewards, and platforms like these are redefining the way we experience games. What’s your go-to online activity during downtime?
That’s a clever way to modernize the classic spin to win concept! Using Xibo and an embedded iframe makes it way more flexible than a physical wheel, plus it’s easier to update and customize.
And btw, you might explore adding sound effects or animations triggered when the wheel lands on a result—it could make the interaction feel even more immersive. Also, much like tweaking a digital campaign, fine-tuning gameplay settings can give you an edge, just like Apex cheats with ESP, aimbot, and customizable features can help refine strategies in Apex Legends. Have you tested it in a live setting yet?
