Backround image not showing up on my template
Hi guys!
Hoping to get some help me after spending hours trying to figure this out.
I’ve got a menu board that was working fine, and I tried updating the backround image using a PNG first, realizing I should stick with a jpeg after multiple failed attempts to see the backround image when I published. Now the JPG wont show up either. HELP!
Is there a reason why XIBO wouldnt show the backround image? Using the latest version of Xibo.
I think as long as it’s not a CMYK it would work ok. I usually use PNG, can you export your layout and share it here?
