I’ve seen this tutorial to automate the registration on webOS devices : https://xibo.org.uk/docs/setup/automating-cms-credentials-for-the-webos-player
Is there any way to do the same on an android device like the DSCS9 ?
Thank you
Thank you
Not in the same way no.
If you have a white label, then if you open a ticket with the service desk we can build in the CMS URL and key in to the APK for you so that it will install, and then when run it will connect to a fixed CMS automatically.
Great, we will look into that then.
Thank you for the quick response
