Automating API calls
how would I go about automating this process? For example a Video that needs to be replaced every Monday, because the mediaID changes every time a file is uploaded/replaced?
I guess the POST command can be done via a cronjob.
I’d recommend using tags to identify your media record across revisions - during your weekly upload you can query for media with a particular tag, get the ID and issue the replace.
So /library?media=tag gets me the ID, how do I input that into my replace commad?
Can it be done in a single POST command and/or script?
One call? No.
One script? Yes
You’d need to GET the mediaIDs with the required tag and then use those IDs in your POST call in the ā€˜oldMediaId’ parameter.
Please also be advised that the documentation for deleting old revisions is wrong it should be deleteOldRevisions.
Apparently I am out of my depth with this, are their any good resources you would recommend on working with this type of API and scripting them?
So I am using the following in the Tests section, however it is not producing the EnvironmentVariable like it is supposed to:
var jsonData = JSON.parse(responseBody);
postman.setEnvironmentVariable("oldMediaIDrequest", jsonData.mediaId);
GET {{url}}/api//library?media=mmtv produces the following
        "mediaId": 132,
        "ownerId": 1,
Postman is a tool for API testing and exploration - its been provided so people can see an example of how an API might function.
I don’t think we’ve tested using Postman to actually run a ā€œcompleteā€ script.
That being said, the response body is an array, so you’d probably want:
postman.setEnvironmentVariable("oldMediaIDrequest", jsonData[0].mediaId);
What programming language do you intend to use once you get this up and running?
Ah, yeah that works. I’m leaning towards PHP, as I have no experience with Python… Thank you for your help so far!
