Hi, I’m just started using Xibo. I need to change/ update the images in the layout every morning. Is there a way to auto update the images? The layout is still remain the same from day to day.
If those images are uploaded to CMS library, then you’d need to edit the media in CMS library and replace it with a new one - don’t forget to check the checkbox to update it in all layouts it’s assigned to.
