Looking for a script that can auto install docket with specifics from a form for install.
Want clients to be able to sign up like on Xibo in the cloud but on our private server.
Thanks !
Specify the full CMS version you are using, including the revision number.
Installation Method
Docker or Custom install
Operating System
The operating system the CMS is installed on
Please describe in detail the issue you are experiencing, including any errors shown in the Logs section of the CMS.
Provide screenshots where possible!
