I am happy.
I tested a few competitors but they were difficult to get working. Xibo has fit the bill quite nicely, and since it’s given away free and the Android licenses are quite affordable I feel the need to give back.
I found an easy way to get SSRS to display on Android clients.
I hope this helps.
Create a file on the root of your inetpub folder on your SSRS machine with an asp extension.
(you can get fancy and create a virtual directory and put the file in that folder, but it must use the same domain name due to cross-domain scripting blocking in modern browsers)
Paste the code below and modify the CREDS variable to a user that has access to view the report.
Change the “Link-to-your-report&rs:Command=Render&rc:Toolbar=false” to the location of the report you want to use.
Use a ReportServer link.
In your layout create a region and choose webpage, set the link to http://SSRSServer.domain.com/File-you-created.asp
this will redirect Xibo to your report with the credentials you added to the file.
Code below
<html> <head> <script> var CREDS=["user","password"]; function getHTTPObject() { if (typeof XMLHttpRequest != 'undefined') { return new XMLHttpRequest(); } try { return new ActiveXObject("Msxml2.XMLHTTP"); } catch (e) { try { return new ActiveXObject("Microsoft.XMLHTTP"); } catch (e) {} } return false; } function runReport() { var http = getHTTPObject(); var url= "Link-to-your-report&rs:Command=Render&rc:Toolbar=false"; http.onreadystatechange = function() { if (http.readyState == 4) { if (http.status == 401) { runReport(); } if (http.status == 200) { document.location = url; } } }; http.open("get", url, true, CREDS[0x0], CREDS[0x1]); http.send(null); return false; } </script> </head> <body onload="runReport();"> </body>
The close html isn’t showing, make sure you close your tags.
I’m sorry if this is common knowledge, but maybe it will save another newb some time and effort.
Reference: https://tickett.wordpress.com/2014/12/03/anonymous-authentication-sql-server-reporting-services/
