Hi, I have a layout using Audio file, but I as well use an overlay layout with its own audio file. When the overlay layout is coming up, both audio files are playing. Is there a way to avoid this and only play audio from Overlay layout ?
Hi, you could have a version of the main layout you are using without audio and have that running when you want to use the overlay to avoid both files playing.
