Is it possible to create asymmetric video wall like this?
not with Xibo that i know of.
they are using some sort of scaler to render to the screens. either raspberry pi or special purpose.
The above user is correct, this cannot be done using Xibo. Xibo can be used to create a video wall, but changing the angle of the displays in this way is done at the hardware level, using specialised equipment.
ok. Thanks for reply.
