Are "gif animated" supported by Xibo for Android
I tried to add gif animated files in my presentation. I’m able to do it with the Windows player, but with “Xibo 1.7 R60 for Android” (Installed on a “NEO Z64-A”) the gif animated file display only the first image, but don’t display the annimation.
Do you have some infos ?
Best regards
Sorry, animated GIF’s are not supported by Xibo for Android
try this
GIF can be displayed by image module or you can put on slideshow and then display by slideshow module
