Hello
I using Xibo for android. I assigned around 20 images, then some times Xibo client has been restarted.
Can you please help me!
Hello
Could you tell me which xibo for android version you use?
Correct me if I am wrong, you created layout with ~20 images scheduled it to display on your android device and after some time application closed (without any crash/error message) and restarted, correct?
If you could schedule it again and see if you can reproduce it? (mainly see if you can see a pattern - ie that it crashes always in the same time - between 2 specific images for example)
thanks
Hello Peter
I using Last version (1.7R54). Yes, Absolutely correct, I tried with another layout and have same problem.
TQ
Ok, I believe it is similar (if not the same) issue as here:
Just to confirm could you please take the same steps as in this topic?
Other than that, same as there, I can tell you that we are working to fix this.
Hi Peter
I sent to you
tq
Hello
I reduced number of images to 4 and its working well. Hope to find a solution about this issue
Thank you
I noticed the same problem with many tickers (10 more sources) in the Layout in a region.
