I don’t know what value I had to put in the field “collect interval”. Or maybe is a problem of the download window start time and the download window finish time.
Well in resume the display has been on for more than two hours and has not yet been updated.
How can I solve it? Thanks
I have changed the download window time to 00:00 - 00:00
Xibo starts but it seems to be hunging because it doesn´t show any layout. I have to reset the player or leave it for a while to see if it is updated?. I’m afraid it will not update at all.
Everytime I make a change to the layout is changed in the player or is the slide updated only when the player starts?
If you change the content, then the Player will update itself either when the CMS notifies it of the change (assuming you have XMR configured and working properly), or when the Player polls for new content (which is the collection interval you’ve configured).
If it isn’t showing your layout, then first go to the Modules page of the CMS and click on Verify All, and then next check that your layout is valid.
