We have purchased some xibo dscs9 player.
And at the first Boot the player ask us witch launcher we want to use.
What is the best choice ?
Thanks.
Thanks.
Hello and welcome to the Community!
We would recommend “Use Launcher as Home” and “ALWAYS” unless there is a need to use Xibo as the Launcher.
When the device boots, it will go to the desktop, and then a minute or so later Xibo will start. This is deliberate as it allows time for the device to set up its networking, set the correct date and time etc before Xibo starts running. This allows time for external storage to become available if you are using those with the Player and avoids potential issues around date/time settings.
You have the option to change this at anytime in the System Settings if required.
Thanks for your fast reply.
