Android cms connection error
We have been running xibo for quite a while without a problem.
We have recently changed web hosts and performed a fresh install of v 1.7.4 CMS
All installed fine & I’ve imported a few layouts without an issue.
I’m now at the stage where I need to connect the displays. These are smart TV’s running android with the xibo app installed - they have been running connected to the previous URL for a while.
When I go to connect to the new URL I get the message “unable to register due to error : Null”
If I try to connect to a random URL it complains that it cant connect - but putting in the new URL it sits there for a minute or so before issuing the error.
Is there something I need to set up to add the display to the CMS ?
It would imply that player can’t reach the CMS, is there anything in the environment that could actively block/interfere with the connections between android player and CMS?
Can you reach the new CMS url in the default android browser on the android device?
Hi Peter,
Thanks for the response.
I changed the connection URL to the IP address of the server hosting xibo and it connected fine & all working.
Regards,
Alan
