Hi, anybody know a model of android box that support vertical rotation? I try different model, with “rotate app” a set portrait or landscape but resize the video not set correct the view.
You will need a device that supports screen rotation and video rotation (and video in appropriate resolution of course).
After that you will also need special display profile created in CMS (with correct portrait resolution in ‘Location’ tab)
The two top devices on our list (dsdevices and z64) support screen rotation (z64 needs updated firmware to do that) - Recommended Android Hardware
