Do not know why, and it does not seems to matter how I do it, either by setting a display profile or overriding the setting for each display - the automatic reboot-setting always reverts to true. I edit the Android display profile, uncheck the automatic reboot-box and then save it. When I edit it again the box is checked. Any idea why?
Have a display that is not supposed to revert back to Xibo if someone change source (ie to use hdmi).
Thank you for your message. can you confirm what version of CMS you are using?
Further to my previous message, the issue you are experiencing is related to a bug. The issue has been resolved and a fix will be aplied to the next release of V2 CMS (2.0.2). I have included a link to the report for further information:
My apologies for any inconvenience caused in the meantime.
Thanks for the information regarding the bug. I will await the update.
(The CMS version is 2.0.0 and players are on android 2-201)
