Hi. Having problems with the 401 Android client on some Samsung Tab A8’s.
Client installs fine, but when you run it, the tablet semi locks up and the app doesn’t go past showing the icon in the middle of the screen. I can go back and run 311 and that works perfectly.
Not sure how much more info I can give you (beside tablet specs) as the app never gets into enough of a working state to be able to get into the menu!
Tablets running Android 13
