I am running the latest xibo version 4.0.7 and I currently have displays showing different slideshows of images. It has been working great for years, but I have recently taken over administrating this app. My issue is that I am unable to add new images to the slideshows. I was able to successfully add the new image to the library, however once it’s in the library, I have no idea where to go from here. Documentation mentions adding new media to layouts and playlists, however when I’m logged in, I do not see any layouts or playlists. I’m not sure how this is possible as I currently have active displays working as expected. I am obviously missing something. Any help would be much appreciated.
Did you received a new account, could be a permission issue. If the permissions are set correct, you should see everything
ok so after review, I was able to view the layouts and after enabling the image library search module was able to update the layouts with newly uploaded images.
