Version 2.3.2.
Installation Method
Docker
Operating System
Windows 10 Enterprise 1809
I’d like to use the Weather widget (forecastio) to display the weather. Unfortunately we use a proxy that swaps the SSL certificate with one of its own. I entered our proxy in the Xibo settings, but due to this issue I get this error in the Xibo log when I try to get weather data:
Unable to reach Forecast API: cURL error 60: SSL certificate problem: unable to get local issuer certificate (see https://curl.haxx.se/libcurl/c/libcurl-errors.html)
I have the certificate available in .cert and .pem formats and would like to add this certificate to the Docker container so I can connect to DarkSky.
Is this possible?
