Hi, we’ve started playing with a touch display and using actions to change to a particular widget on the current layout.
This seems a little convoluted at the moment where we have to duplicate every single widget we already have in the layout into the Actions Toggle drawer in able to be able to switch to them on touch.
We’d rather be able to point the action to switch to an existing widget that is already in the in the region without having to have two copies of it.
Hi. thank you for providing feedback on Interactive Actions!
So we can better understand the issue you are currently finding with actions could you give us an example of what you are trying to achieve if possible?
Many thanks
