will Xibo work with Acer Veriton N2010G thin client
The Xibo player software needs a local disk to store a cache of the content on, so Thin clients usually aren’t a good choice as they are diskless.
the cms will be on our main school serverr
Makes no difference where the CMS is. The Player needs a local disk to store a cache of the content from the CMS on. They’re also ARM based so if you can get Windows running locally on them then I suspect they’ll struggle for power.
You may get it working as a traditional thin client, with the Player running on a terminal server, but it’s not a configuration the project supports. The Player software should be running on the device attached to the TV directly.
