4.0.6 CMS Installation error
Installation Method
Custom install
Operating System
WIN - XAMPP
when i install the software i face this in my webhost and in my personal server …
404 Not Found
The application could not run because of the following error:
Details
Type: Slim\Exception\HttpNotFoundException
Code: 404
Message: Not found.
File: C:\xampp\htdocs\xibo\vendor\slim\slim\Slim\Middleware\RoutingMiddleware.php
Line: 76
Trace
#0 C:\xampp\htdocs\xibo\vendor\slim\slim\Slim\Middleware\RoutingMiddleware.php(44): Slim\Middleware\RoutingMiddleware->performRouting(Object(Slim\Http\ServerRequest)) #1 C:\xampp\htdocs\xibo\vendor\slim\slim\Slim\MiddlewareDispatcher.php(121): Slim\Middleware\RoutingMiddleware->process(Object(Slim\Http\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous)) #2 C:\xampp\htdocs\xibo\vendor\slim\slim\Slim\Middleware\ErrorMiddleware.php(76): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Http\ServerRequest)) #3 C:\xampp\htdocs\xibo\vendor\slim\slim\Slim\MiddlewareDispatcher.php(121): Slim\Middleware\ErrorMiddleware->process(Object(Slim\Http\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous)) #4 C:\xampp\htdocs\xibo\vendor\slim\slim\Slim\MiddlewareDispatcher.php(65): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(Slim\Http\ServerRequest)) #5 C:\xampp\htdocs\xibo\vendor\slim\slim\Slim\App.php(199): Slim\MiddlewareDispatcher->handle(Object(Slim\Http\ServerRequest)) #6 C:\xampp\htdocs\xibo\vendor\slim\slim\Slim\App.php(183): Slim\App->handle(Object(Slim\Http\ServerRequest)) #7 C:\xampp\htdocs\xibo\web\install\index.php(101): Slim\App->run() #8 {main}
i fix the error by my self … done
I’m getting the same errors you’re getting. Can you tell me how you solved it?
look at this video and you will make it
