3.1.0-beta
IIS Server PHP 7.2
Guys!
It throws an error during the phinx migration:
I was trying to migrate from 3.0.7 to 3.1.0-beta (IIS Instalation)
Any suggestion?
thanks!
3.1.0-beta
IIS Server PHP 7.2
Guys!
Any suggestion?
thanks!
Hi, what version MySQL are you using?
Hi Natasha!
Here it is:
I have other CMS databases working fine on this server, including 3.0.x version and one 3.1.0-beta version manually installed
Thank you!
Ironically I ran into this too - root cause for me was the aouth_clients table being latin1 instead of utf8.
I think this would solve it
ALTER TABLE `aouth_clients` CHARACTER SET utf8 COLLATE utf8_general_ci
Edit: bug created for this here:
Thanks,
Dan
Hi Dan and Natasha!
Thank’s again for the answer!
For me it was also necessary to update the Collation of the Columns to utf8_general_ci
ALTER TABLE `oauth_clients`
CHANGE COLUMN `id` `id` VARCHAR(254) CHARACTER SET 'utf8' COLLATE 'utf8_general_ci' NOT NULL ,
CHANGE COLUMN `secret` `secret` VARCHAR(254) CHARACTER SET 'utf8' COLLATE 'utf8_general_ci' NOT NULL ,
CHANGE COLUMN `name` `name` VARCHAR(254) CHARACTER SET 'utf8' COLLATE 'utf8_general_ci' NOT NULL ;
But it works for me.
Thank you!
