system
1
We are pleased to announce the release of our first release candidate for the 3.0 version of Xibo. The codename for this version is “Finlay”.
This is a companion discussion topic for the original entry at https://blog.xibo.org.uk/3-0-0-rc1-released/
I just tried to migrate from 2.3.8 v to 3.0.0-rc 1 on my Apache server and get migration error:
== 20201007093511 FeaturesMigration: migrating
In PdoAdapter.php line 134:
SQLSTATE[42000]: Syntax error or access violation: 1074 Column length too big for column ‘featu
res’ (max = 21844); use BLOB or TEXT instead
migrate [-c|–configuration CONFIGURATION] [-p|–parser PARSER] [-e|–environment ENVIRONMENT] [-t|–target TARGET] [-d|–date DATE] [-x|–dry-run]
dagonix
3
I can’t wait to try it ! Thank you for making Xibo better year after year.
Can you please open the V3 branch in Launchpad translations ?
Thank you.
same here , any fix found
dan
5
Thanks for reporting this - i’ve created an issue for it and we will investigate
dan
6
Thank you for your kind comments!
Yes definitely - its open now: Series 3.0 : Translations : Xibo
Thanks!
dan
7
still getting the below error even with fresh installation
dan
10
