1045 Acess dennied
CMS Version 2.3.8
Installation Method
Custom install
Operating System
windowns 64, no internet access
Please describe in detail the issue you are experiencing, including any errors shown in the Logs section of the CMS.
Fatal Error - sorry this shouldn’t happen. SQLSTATE[HY000] [1045] Access denied for user ‘xibo_admin’@‘localhost’ (using password: YES)
ERROR LOG:[Warning] Access denied for user ‘xibo_admin’@‘localhost’ (using password: YES)
I’m sure I’m not getting the password wrong
Not sure how you did this but recheck your MYSQL query you did.
If you could, reset password for SQL user…
I had to reinstall the web part. I don’t know if there was another option.
