1.8 When PC starts, Xibo automatically minimises, how can I fix this?
When our PC starts, Xibo automatically minimises, how can I fix this so that Xibo automatically starts and continues to play full screen?
That seems rather odd, both 1.7.8 and 1.8 beta Xibo for Windows clients come with ‘always on top’ setting, to avoid situations like this one you described.
Do you have any other programs that start on Windows start-up?
No, it is a brand new PC, and we have only loaded Xibo Client on to it.
Perhaps your display settings profile in the CMS has the screen set with a small size or offset configured?
What version of windows are you running? Also unless you installed windows yourself, there is going to be other programs starting up. Double check and see what are starting up.
