1.8-rc1 Dataset Columns when Null
I have a dataset widget that has 6 Columns selected. A couple of these columns are Designated as ‘Library Image’.
If a column is left blank (i.e. null / no image set), then I notice Xibo excludes the column from the generated HTML table altogether - as per the image below. Row 4 has the image set (Column 4), whereas rows 1 to 3 do not.
This causes the table to shift data out of its correct position.
Also, I notice that Column ID numbering starts at 2. Column_1 is never present for some reason.
Could you provide an export of your Layout containing the DataSet widget (including DataSet data). I’m not sure what is happening for you because it appears to work here.
Was this a fresh install or upgrade?
