Hi!
It’s not possible for me to setup any members in a Display Group?
All other options open up a menu but the highligted members text is not clickable.
Hi!
Right, there was a bug with this form.
Please have a look at this bug report, it describes the problem and also in the latest comment you can find a workaround
Simply download the archive attached in the issue and extract to the /vendor
folder and you will get back your missing files.
Thank you. Where do I search for known bugs and fixes so I don’t ask again when answer is out there =)
The confirmed bugs and enhancements are in GitHub - https://github.com/xibosignage/xibo/issues (you can filter them by labels / milestones (versions))
