1.8 Beta DataSet Import Not Working
Trying to get DataSet CSV Import working on 1.8 Beta (docker version) but not having any luck.
When I upload the CSV, it appears the feild mappings aren’t appearing. Then when you click ‘Done’ it doens’t give any sort of Success / Fail message. The Dataset is then updated with only blank rows.
Can you please test this?
UPDATE:
It also appears that you can add multiple files in this upload dialog which then results in errors.
Thanks,
Justin
This should be resolved in the upcoming release candidate already.
Thanks for letting us know
