1.8 Alpha2 Statistics CMS - Date Selectors
The Date selectors on the 1.8 Alpha2 Statistics page starts off at 1899. When you try to select something, well, you pretty much just get garbage back in the selector box.
This has been solved already I believe (or at least I don’t see the same issue)
It has been a few weeks now since we last reloaded the github code. Do you happen to know if this was fixed recently?
I actually though it had been fixed some time ago - we are hopefully going to push out another update this week, perhaps you can wait for that?
Sure no problem. :sunglasses:
