1.8 Alpha - Module Check Boxes
Check boxes under the modules page do not populate correctly. All show empty even though they are not.
We had this problem with enabling the Audit logs, and a fix was made. I just can’t find what we worked out to fix the other one.
UPDATE: Found how it was fixed here, but not where exactly to fix it.
@peter - can you confirm and submit a bug?
