My boss is eager to start using the PDF functionality, so he has me upgrading to 1.8 RC2. It’s a standalone install (not docker) on xampp.
I copied files to a new folder, changed the webroot and started the install. I chose to use the existing database and entered the info. the first thing I’m prompted with is:
An error occurred populating the database. Statement number: 74. Error Message = [SQLSTATE[42S22]: Column not found: 1054 Unknown column ‘isSystemNotification’ in ‘field list’]. File = [data.sql]. SQL = [INSERT INTO group
(groupID
, group
, IsUserSpecific
, IsEveryone
, isSystemNotification
) VALUES (1, ‘Users’, 0, 0, 0), (2, ‘Everyone’, 0, 1, 0), (3, ‘xibo_admin’, 1, 0, 1), (4, ‘System Notifications’, 0, 0, 1)].
If I click ‘next’ again, I get
Base table or view already exists: 1050 Table ‘oauth_client_scopes’ already exists
If I choose a fresh DB, I can install, but no library, no layouts, no displays. I would like to keep the old DB so my layouts, displays and other settings are kept.
help?
John
