Hi
I’m trying to use the CMS functions via 3rdparty apps, to do so I’m using php libcURL.
The problem is that when I’m calling the CMS functions I return empty responses, cURL logs no errors.
As I’m new to developpement I assume the error is from my code but even walking through the community posts but I didn’t found any clue to resolve my issue.
Here is a part of my calls:
function libraryupload(){
$url = 'http://localhost:8080/xibo/3rdparty/cmsapi/xibo-functions.php';
$curl = curl_init();
curl_setopt($curl,CURLOPT_URL,$url.'?'."action=LibraryMediaFileUpload");
curl_setopt($curl,CURLOPT_RETURNTRANSFER,true);
curl_setopt($curl, CURLOPT_USERAGENT , "Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1)");
curl_setopt($curl, CURLOPT_CONNECTTIMEOUT , 7);
curl_setopt($curl,CURLOPT_FAILONERROR,true);
curl_setopt($curl, CURLOPT_HEADER, true);
$curl_response = curl_exec($curl);
$info = curl_getinfo($curl);
if (!curl_errno($curl))
$data = json_decode($curl_response, true);
return $data;
else
printf("cUrl error (#%d): %s<br>\n", curl_errno($curl),
htmlspecialchars(curl_error($curl)));
curl_close($curl);
“xibo-functions.php” is just “index.php” in Oauth2 folder renamed.
I’ve also edited the function called:
function LibraryMediaFileUpload() {
// Get the test file
$file = file_get_contents('../imagen/editImg/agenda2016.jpg');
$payload = base64_encode($file);
$params = array(
'service' => 'rest',
'method' => 'LibraryMediaFileUpload',
'response' => RESPONSE,
'fileId' => NULL,
'checksum' => md5($payload),
'payload' => $payload
callService($params, true);
$params0 = array(
'method' => 'LibraryMediaAdd',
'fileId' => NULL,
'type' => 'image',
'name' => 'Test image',
'duration' => '15',
'fileName' => '../imagen/editImg/agenda2016.jpg'
callService($params0, true);
A variant with verbose shows:
Verbose information:
- Hostname was found in DNS cache
- Trying ::1…
- Connected to localhost (::1) port 8080 (#9)
GET /xibo/3rdparty/cmsapi/xibo-functions.php?action=LibraryMediaFileUpload HTTP/1.1
User-Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1)
Host: localhost:8080
Accept: /< HTTP/1.1 200 OK
< Date: Wed, 30 Nov 2016 15:54:19 GMT
- Server Apache/2.4.9 (Win64) PHP/5.5.12 is not blacklisted
< Server: Apache/2.4.9 (Win64) PHP/5.5.12
< X-Powered-By: PHP/5.5.12
< Content-Length: 3132
< Content-Type: text/html
<- Connection #9 to host localhost left intact
