Ok good to know.
Let me summerize:
With the Xampp 5.6.40 it works and with Xampp 7.3.7 with the ZeroMq 1.1.3-72 not?
Greetings and good to hear that it works.
Torsten
Ok good to know.
Let me summerize:
Torsten
OK i can comprehend the Problem:
Yes; Xampp 7.3.7 with ZeroMQ 1.1.3-7.2 TS x64 is NOT working.
ZeroMQ is working with PHP 7.2.20. but not above this Version.
Thank you Its Worked !!!
and i setup reboot player command bt its not working please Help
Hi
i update my How-To about how to configure the Xmr-Service on a Windows System.
If its not working on your environment, please follow my instructions on the manual.
Please post here if its work an we can do the next Step with sending a reboot command to the player.
Greetings Torsten
