I just built a new 1.8 server using docker yesterday and assigned 2 players with various layouts to it. This morning both players were locked up and the log files were full of this error
"835 2017-04-19 04:30 XMR unresponsive, issue reconfigure.
834 2017-04-19 04:25 Unable to start XMR queue: class java.lang.IllegalArgumentException/java.net.UnknownHostException: Unable to resolve host “cms.example.org”: No address associated with hostname"
This is my first time using docker, I believe I have it configured correctly, this is the output from docker-compose config
root@ds:/opt/xibo/xibo-docker# docker-compose config
networks: {}
services:
cms-db:
environment:
CMS_SERVER_NAME: ds.kharmaconsulting.net
CMS_SMTP_FROM_LINE_OVERRIDE: 'YES'
CMS_SMTP_HOSTNAME: gmail.com
CMS_SMTP_PASSWORD: E
CMS_SMTP_REWRITE_DOMAIN: gmail.com
CMS_SMTP_SERVER: smtp.gmail.com:587
CMS_SMTP_USERNAME: E
CMS_SMTP_USE_STARTTLS: 'YES'
CMS_SMTP_USE_TLS: 'YES'
MYSQL_DATABASE: cms
MYSQL_PASSWORD: E
MYSQL_RANDOM_ROOT_PASSWORD: 'yes'
MYSQL_USER: cms
image: mysql:5.6
mem_limit: 1g
restart: always
volumes:
- /opt/xibo/xibo-docker/shared/db:/var/lib/mysql:rw
cms-web:
environment:
CMS_SMTP_PASSWORD: Kcigp2015!
MYSQL_PASSWORD: E
XMR_HOST: cms-xmr
image: xibosignage/xibo-cms:release_1.8.1
links:
- cms-db:mysql
- cms-xmr:50001
mem_limit: 1g
ports:
- 80:80
restart: always
volumes:
- /opt/xibo/xibo-docker/shared/cms/custom:/var/www/cms/custom:rw
- /opt/xibo/xibo-docker/shared/backup:/var/www/backup:rw
- /opt/xibo/xibo-docker/shared/cms/web/theme/custom:/var/www/cms/web/theme/custom:rw
- /opt/xibo/xibo-docker/shared/cms/library:/var/www/cms/library:rw
- /opt/xibo/xibo-docker/shared/cms/web/userscripts:/var/www/cms/web/userscripts:rw
cms-xmr:
environment:
MYSQL_PASSWORD: E
image: xibosignage/xibo-xmr:release_1.8.1
mem_limit: 256m
ports:
- 9505:9505
restart: always
version: '2.1'
volumes: {}"
