according to here for non-docker installation, I have to put a config.json in order to have push messaging from XMR to cms.
But I’m using xibo docker version 2.1 and the screenshot is not working properly although I set the XMR public address in CMS and moreover, in the displays page it says the screen has registered for XMR.
How should I config the cms and/or docker in order to push messages to displays?!
And by the way, what does this line of code <links: - cms-xmr:50001> do in the docker config file? what is 50001?
