I am using Xibo docker 2.2.2 and Xibo Windows client. when I open the client logs, it says the XMR is connected and waiting for messages. But doesn’t receive a single message.
Do you have any idea what is the reason?
Your XMR address is configured for port 80 which seems very unlikely (port 80 is HTTP).
Please take another look at the guide to see what port you’ve set XMR to run on
well it’s running on 9505 but I’m using apache proxy pass in order to map the 9505 to 80.
Probably best to carry on over here on your other question, seeing as they are related: Sync date and time for device, cms and xmr
Essentially Apache can’t proxy a TCP socket
