Hello ,
do you know how can I insert some data in a layout through a XML files or through a database plz ?
I hearded about an API but i didn’t find it.
Thanks a lot.
Max
Hello ,
Thanks a lot.
Max
Btw , where can i find Xibo’s database plz ?
You shouldn’t really make any direct actions on the database, as for where it is, that depends on your installation and server environment - but I’d strongly suggest not making changes directly in the db.
As for API, assuming you have 1.8 series CMS please see the manual page and linked API documentation in it https://xibo.org.uk/manual/en/cms_api.html
There is also introduction to API topic on this site in the guides category which might be helpful.
