Please anyone who can help me? It keeps on clashed. I encounter one of my workstations.
The error message suggests that the issue is with wmvdecod.dll, which is a wmv playback codec. This is a part of the Windows operating system, not Xibo. It is likely the issue is being caused by a problem with your hardware or Windows.
I would recommend checking Windows and your hardware for faults. Below are a list of suggestions:
- Make sure Windows is up to date.
- If you are using Windows 7, you will find the option to check for updates in your Control Panel, System and Security.
- For Windows 8.1 and Windows 10, you will find the option in your Settings menu.
Make sure all Drivers are up to date. I would recommend going to Company website for your hardware (Graphics card, Motherboard) and checking for new drivers.
Run sfc /scannow from an elevated command prompt, to repair/replace any corrupted system files. To open an elevated command prompt:
- Open the Start menu and type CMD. This will find Command Prompt, which you then have to right click on. From the menu that appears, select Run as Administrator.
- Test your RAM for possible faults. Windows has a built in Memory Diagnostic tool, but others are available to download online.
If you have tried all of the above steps and the issue persists, please let me know.
