Hi, i’ve been running xibo on a few clientes to test its functionality, and in some of those clientes i keep getting error after a while playing the vídeos it pop out a Window saying:
Xibo Open Source encountered a problem and needs to be closed.
On event viewer every time i get this screen it shows te following two events:
Event Type: Error
Event Source: .NET Runtime 4.0 Error Reporting
Event Category: None
Event ID: 1000
Date: 10/08/2016
Time: 15:24:57
User: N/A
Computer: ECE-TVADMIN
Description:
Faulting application xiboclient.exe, version 2.0.0.0, stamp 575193bc, faulting module quartz.dll, version 6.5.2600.6333, stamp 50e3d88c, debug? 0, fault address 0x00031585.
For more information, see Help and Support Center at Microsoft Support.
Data:
0000: 41 00 70 00 70 00 6c 00 A.p.p.l.
0008: 69 00 63 00 61 00 74 00 i.c.a.t.
0010: 69 00 6f 00 6e 00 20 00 i.o.n. .
0018: 46 00 61 00 69 00 6c 00 F.a.i.l.
0020: 75 00 72 00 65 00 20 00 u.r.e. .
0028: 20 00 78 00 69 00 62 00 .x.i.b.
0030: 6f 00 63 00 6c 00 69 00 o.c.l.i.
0038: 65 00 6e 00 74 00 2e 00 e.n.t…
0040: 65 00 78 00 65 00 20 00 e.x.e. .
0048: 32 00 2e 00 30 00 2e 00 2…0…
0050: 30 00 2e 00 30 00 20 00 0…0. .
0058: 35 00 37 00 35 00 31 00 5.7.5.1.
0060: 39 00 33 00 62 00 63 00 9.3.b.c.
0068: 20 00 69 00 6e 00 20 00 .i.n. .
0070: 71 00 75 00 61 00 72 00 q.u.a.r.
0078: 74 00 7a 00 2e 00 64 00 t.z…d.
0080: 6c 00 6c 00 20 00 36 00 l.l. .6.
0088: 2e 00 35 00 2e 00 32 00 …5…2.
0090: 36 00 30 00 30 00 2e 00 6.0.0…
0098: 36 00 33 00 33 00 33 00 6.3.3.3.
00a0: 20 00 35 00 30 00 65 00 .5.0.e.
00a8: 33 00 64 00 38 00 38 00 3.d.8.8.
00b0: 63 00 20 00 66 00 44 00 c. .f.D.
00b8: 65 00 62 00 75 00 67 00 e.b.u.g.
00c0: 20 00 30 00 20 00 61 00 .0. .a.
00c8: 74 00 20 00 6f 00 66 00 t. .o.f.
00d0: 66 00 73 00 65 00 74 00 f.s.e.t.
00d8: 20 00 30 00 30 00 30 00 .0.0.0.
00e0: 33 00 31 00 35 00 38 00 3.1.5.8.
00e8: 35 00 0d 00 0a 00 5…
and
Event Type: Error
Event ID: 1026
Date: 10/08/2016
Time: 16:08:58
User: N/A
Description:
Aplicativo: XiboClient.exe
Versão do Framework: v4.0.30319
Descrição: O processo foi terminado devido a uma exceção sem tratamento.
Informações da Exceção: código da exceção c0000005, endereço da exceção 74801585
I’m running crazy because of this problem since i have the exactly the same configuration on all computers and only a few shown this error.
I tried to update .Net but it hasn’t fixed the problem, also i tried to completely remove .Net and reinstall it, still the error occur.
I’ve checked virtual memory, codecs and also the media player but nothing resolved this problem.
Have anyone ever found this error or could give some tips to where do i have to look to fix it?
