XIBO without docker
Does installing Xibo 1.8.1 without docker impacts any functionality ?
I was not able to find any documentation referring to any limitations on functionality.
If you will install everything (including zeroMQ for XMR etc) as described here http://xibo.org.uk/manual/en/manual_install.html
and then manually modify the environment settings like DocumentRoot, url rewriting etc - http://xibo.org.uk/manual/en/install_environment.html
Then you will not miss any functionality and everything should work fine.
As stated many times, docker is not a requirement it’s just recommended.
