XIBO WEBOS Player Keep on Loading
Hi
I am just testing the xibo webos lg player in lg display.
If the internet is good it works fine .
If the internet speed is poor ,the display shows just loading indication .keep on trying loading .
So what is the solution for playing the loaded content with out loading
What monitor model are you using please?
Do you have online content scheduled to it? (webpages, embedded content etc)
screenshot/photo of the player status when it is in that state could be helpful as well.
Just to confirm which Xibo for webOS version do you have installed on it and which CMS version do you have at the moment?
