Xibo Ticker stutters
we want to use a ticker in text format.
Works, but it stutters every second once.
Does anyone has a solution?
Xibo Client 1.7.5
Xibo Server 1.7.4
The hardware is top.
It would be good to upgrade to the newest versions both CMS and players.
I assume you’re talking about marquee effect, it can be quite cpu intensive.
What hardware is it please?
I assume it is windows client, it would be best to, make sure you have IE 11 installed and 1.7.8 client.
Computer with windows 10 64bit:
Intel Celeron 3205U 2x1,5 GHz
SSD
4GB RAM
On my computer is the same Problem
Intel Core i5 4460 4x3,2 GHz
SSD
8GB RAM
Client 1.7.8 has been installed but no change
