Xibo installed on windows docker had been working fine and now the ticker dataset in the main region of the screen is just blank. Even in preview layout mode the data does not display anymore
Do you have any filters set in the Ticker?
I assume there is still data in the dataSet and that on the Ticker Appearance tab you do have correct column names added from the substitutions?
