XIBO through VPN-Tunnel
we want to use XIBO Player through a VPN-Tunnel. Once the tunnel ist established, the players can retrieve content from the cms, am i right?
Btw. is there a option to push content to players manually and see its progress?
Thanks Marco
Assuming there’s a network connection which you can pass HTTP traffic over, then it should work OK yes.
There’s no option to push content down. The CMS has no connection to the Player. The Player polls for content on a schedule and collects updated content.
From 1.8 series onwards, there is XMR - a push technology that allows the CMS to signal to the Player that there is new content for it to download which lowers the time it takes for content to be pushed out, and also removes the requirement for frequent polling of the CMS for content updates.
