Xibo schedule not updating
I’m debugging in the client, and no matter how many events I program in the server, the schedule xml I receiving in the ScheduleAgent is always:
<schedule>
       <layout file="6" fromdt="2016-04-19 13:30:00" todt="2016-04-19 22:15:00" scheduleid="2" priority="1" dependents="18.png"/>
       <layout file="6" fromdt="2016-04-19 13:30:00" todt="2016-04-19 22:50:00" scheduleid="3" priority="1" dependents="18.png"/>
       <layout file="6" fromdt="2016-04-19 13:30:00" todt="2016-04-19 22:50:00" scheduleid="4" priority="1" dependents="18.png"/>
       <default file="5"/>
I erased those 3 events corresponding to layout file 6 in the server and they still appear in the received xml. Programmed new events with another layout and it’s not appearing here
<schedule>
<default file="5"/>
schedule
layout file=β€œ6” fromdt=β€œ2016-04-19 13:30:00” todt=β€œ2016-04-19 22:15:00” scheduleid=β€œ2” priority=β€œ1” dependents="18.png"
layout file=β€œ6” fromdt=β€œ2016-04-19 13:30:00” todt=β€œ2016-04-19 22:50:00” scheduleid=β€œ3” priority=β€œ1” dependents="18.png"
layout file=β€œ6” fromdt=β€œ2016-04-19 13:30:00” todt=β€œ2016-04-19 22:50:00” scheduleid=β€œ4” priority=β€œ1” dependents="18.png"
default file=β€œ5”
I removed the symbols < and > cause I don’t know how to post xml
What CMS version are you using?
Have you set a fully qualified path to the CMS library in the settings? Or a relative one?
I’m using 1.7.7.
I had a relative one. I have set a full path and now it’s working.
Thank you very much!
