Logged into my Xibo install today, couldn’t log in with my admin password, eventually worked out that everything has gone and Xibo has returned to default
Anybody got any idea why this could have happened?
Gary
Gary
it’s actually reverting to defaults every time I restart the computer.
If you’re using docker for Windows, then it is most likely this problem, please see the manual page it also includes the fix for it - which thankfully is very easy - https://xibo.org.uk/manual/en/install_docker_win10_64bit.html#special_considerations
Thanks all is back to normal
