Hello i’m creating an Xibo project.
And I want for example
A Text diplayed in a region on xibo
Welcome to our Store “Family name” enjoy your stay!
Could it be possible for an external user to insert only the Family Name?
And ad some text into the specific region only?
Without loggin into Xibo?
I don’t believe there is a way they can directly affect the content on the display without logging into Xibo, but you could use a website to handle this function for you. If you have a system with their information somewhere, you can access and publish that onto a website and then display the website in Xibo via an embedded site.
I realize this was asked a while ago, but maybe this will help someone else.
If can use a web page on the region and change the content according to user input.
