Xibo Player just running 1 second and then my Minix Neo X7 always restart
Dear Support,
I have trouble, Xibo Player just running 1 second and then my Minix Neo X7 always restart. I use cms xibo 1.7.9
Please help me.
Have you removed and then re-installed Xibo? If that doesn’t work, I think you will need to re-image your device. If that does not work, your box is probably bad.
